Just been having a look in the shed and there's stuff here I'm never going to use as my last Xl has gone.
Most of this is xl250s
Wheels, forks, and swing arm are 500s.
and some of each here.
I want it out of the way so if you see something you want let me know. I don't want to be sending bits everywhere so if you see something come get it or it'll go in a lump to the scrappy.
Sick of moving it around.
Cattleclan,, i just posted a thread in the xl bit,,im looking for a 23 inch tyre a 18 inch tyre id n=maybe interested in the wheel too , but am really looking for a front end, with a 21 inch wheel/tyre on it,, have a look at my post please... thanks, john..an would ye semd it to scotland my any chance... or where are you.? thanks.. john
I'm looking for a rear wheel with a drum brake for a dominator crosser conversion
could you compare it with your own .and let me know the outcome
might even do a swinging arm swap since you have one
John.
I might have a dominator front end, i'll check later. No 23" tyres sorry.
Nortchul
Swing arm is a twin shock model, (xl500s) so you'll have some fun getting the shocks sorted although it has been done. If you went that way I have the comp brake plate, sprocket carrier and wheel spindle with all the spacers.
The dominator swing arm is i little narrower than the xl but there's scope to trim the xl spacers to get it in. You'd have to watch the sprocket alignment carefully.
swinging arm swop might be a step too far, what do you want for wheel and all the other bits?
next problem is I'm stuck in the middle of the north sea for another 3 weeks, and live just outside Belfast
