Any one had one any info ?? are they worth looking for as they are not that common :mrgreen:
bike nut
cool bikes
not imported into the UK by Honda, most find there way here from America
Basically a more road going XR600
From what i understand it is dommi engine in xr600 frame :thumbright:
I have one and rate it. you need a bigger tank as the standard runs out at 90 miles.
Also if you look at one make sure that Dave's mods have been done and it has a easier breathing exhaust ie Q4 or the like.
Thanks for that what are daves mod's :thumbright:
Here is a link
[url]http://www.4strokes.com/tech/honda/xr650lcarbmods/
[/URL]
Dave is a merican feller and a guru on these bikes, As standard they run mega lean which is ok but means they run very very hot and the altitude adjuster is not enough to richen the mix up much. but it starts with putting an 0.20 washer on the needle and drilling the hole in the diaphram case out to 5/32 then filing the alt adjuster so that you can in effect over adjust it this brings the running temp down to a less scarey level.
Thanks for that seen any for sale :thumbright:
