1 - 2 of 2 Posts
I have just bought a 05 xr125l it does however need a new carb. I have found carbs that will fit and work but none seem to have the heater like the stock one fitted. If I got a
standard carb with no heater will it run ok or so I need one with the carb heater.
thank you :)
Discussion Starter #2
Ok got the bike running but the mix screw on the original carb has no effect so probably going to swap the carb over to the clone. Again tho does anyone know if it matters that the replacement has no heater on it
1 - 2 of 2 Posts
