Expat Stu
Hi all! My bike is leaking coolant from the little joining pipe between the 2 barrels - can it be fixed in situ, or is an engine out job? Usually Google is my friend, but I need help in a hurry!thanks for any / all replies TA!
The pipe can be wobbled back & too to expose the o rings.
Sometimes rotating the pipe while spraying with ed40 etc can be enough to improve it.
As per previous post remove the clips, slide one end into its barrel, replace o ring, slide other end into its barrel and replace other o ring.
