Hello everyone
I own an old 92 RD04. Recently the Tripmaster has stopped keeping memory, or, when the ignition is turned off for a minute or so, then turned back on again, the clock needs reset.
I have checked the wiring and is getting a battery positive to the trip master, along with an earth and an ignition positive. I have seen a few threads about capacitors etc. Can anyone recommend a drawing or repair procedure, and which capacitors to change etc.
Thanks in advance.
I had one repaired by him, good communications and guarantee of work done plus fairly fast turn round
Hello everyone
Thanks in advance.
Hi,
just "new" Afrika 98 owner. beeing electronics engineer I also decided to fix my tripmaster. It had broken buttons cover so my first action was- open, clean it with pure alcohol, and .. it started to work, but unfortunatelly- got same problem- not keeping data memory. Soooo..... used more alcohol to clean UNDER the reset button. My guess for your case would be- just clean it first- looks like those buttons are intended to make a circuit even if they are not pressed. Hope that could help. And yes... if your silicone covers for the buttons are broken- here it is where you can get them- just few minutes ago called to the guy in Austria- he is sending them to me soon. :)
