So the standard plug for the XRV is DPR8EA-9,
You can also get iridium plugs DPR8EIX-9.
But there also exists the laser iridium plug that is the best plug available on the market, the new CRF Africa Twin uses this plug and the service intervals for spark plugs is 48,000km
Does anybody here know what laser iridium plug will fit the XRV?
I have checked NGK’s website for a cross reference but no results.
89 HRC Africa Twin 650
I think you will find the later (upgraded) plug will not work so well in this engine. Im sure the plug will foul up as its a low compression engine and a slow revving engine. Just put it stock NGK plugs and run Super Unleaded
Really?? Not sure what compression has to do with a plug fouling up .... I run the Iridium NGK plugs in my Twin and never have had a problem.
