1 - 16 of 16 Posts
Discussion Starter #1 (Edited by Moderator)
I have read that there are spare parts for the XRV650 that are interchangeable with other bikes.
(Pattern parts for these items are interchangeable, I'm however certain that HONDA OEM parts differ ever so little from most aftermarket parts
if not in design/quality, at least in price,,,)
I have not tested any of the parts my self, but I will investigate, and test a different rear sprocket next year.
Front sprocket:
15 cog (std): XL600V Transalp 88-99 & XL650V Transalp 00-07 ___ Part number: 23801-MN9-010
16 cog (std): VT600C 90-07, Bros (RC31) & XRV650 Africa Twin 88-89 ___ Part number: 23801-MN8-000
Rear sprocket:
39 cog (std): YAMAHA TRX850 96-99
42 cog (std): YAMAHA TDM900 02-06
47 cog (std): HONDA XL600V Transalp -99 __ Part Number: 41200-MAB-620 (41200-MAW-760 also listed as 47 tooth)
48 cog (std): HONDA XL650V Transalp 00-07 __ Part Number: 41201-MCB-610
49 cog (std): HONDA XRV650 Africa Twin 88-89 __ Part Number: 41200-MS8-610
Rear Brake pads:
BUELL
XB9R Firebolt 02- rear,
XB9S Lightning 03- rear,
XB9SX CityX 05- rear,
XB12R Firebolt 04- rear,
XB12R Lightning 04- rear,
XB12S/Ss Lightning 06- rear,
XB12X Ulysses 06- rear,
HONDA __ Honda original part number: 06435-KT7-405, superseded by 06435-KT7-415
XL600V Transalp 91- rear,
NT650V Deauville 98-00 rear,
NTV650 Revere 90-94, 97 rear,
NX650 Dominator 88-96 rear,
XL650V Transalp 00- rear,
XRV650 Africa Twin rear,
XRV750 Africa Twin -03 rear,
SUZUKI
XF650 Freewind 97- rear,
TRIUMPH
600 Daytona 04- rear,
600 Speed Four 03- rear,
600 TT 00-05 rear,
650 Daytona 05- rear
Front Brake pads:
CAGIVA
900 Canyon i.e. front,
HONDA
VT600 C 88-92 front,
XL600V Transalp 91-93 front,
NX650 Dominator 88-92 front,
XRV650 Africa Twin front,
GL1500J 88- front
Front brake rotor:
Cagiva
Elefant i.e. 90-92 front,
Gran Canyon 900 97-99 front,
Navigator 1000 00- front,
Honda
CB500/E/S 94-96 front,
CB500 97- front, NT650V
Deauville 98- front,
XRV650 Africa Twin 88-89 front,
CB750K 81-84 front,
CB750F 81-83 front,
CB750F2 Sevenfifty 92-99 front,
VFR750F 88-93 front, VT750C2
Shadow 97- front,
CBR1000F 87-95 front,
ST1100 Pan European 02 front
Rear Brake rotor:
"No picture"
Honda
CB500 97- rear,
XL600V Transalp 91-96 rear,
SLR650 rear,
XRV650 Africa Twin 88-89 rear,
CB750F2 Sevenfifty 92-99 rear,
CB900F Hornet 02- rear
Inlet rubbers:
Honda
VT600C Shadow 88-97,
XL600V Transalp 88-99,
XL650V Transalp 00-05,
XRV650 Africa Twin 88-89,
VT750C2 97-02
Stearing stem bearings:
Honda
CR125 84-89,
CR250 84-89,
NX250 Dominator 90,
XR400R 96-04, XL600 83-87,
XL600V Transalp 87-99,
XR600R 86-00,
NX650 Dominator 88-99,
SLR650 Vigor 97-,
XL650V Transalp 00-06,
XLV750R 83. XRV750
Africa Twin 90-00
Rectifier:
Honda
XL600V Transalp 87-96,
XRV650 Africa Twin,
XRV750 Africa Twin 89-97
Rectifier
Honda
XL650V Transalp, 2000 - 2004
VT750C4, 2004
TRX350 00 -03
TRX400 95-02
TRX450 98-01
Administrator
Administrator
Kjell
This is excellent stuff, Thank you very much on behalf of all us RD03 owners.
Hopefully, someone with a bit more savvy than me can work out a good way to archive this on the forum, so it doesn't get lost with a flood of replies in the thread.
Great Work, Thank you again
Bob :thumbup:
Kjell
I'll second that, info like this is invaluable.
Good work
Jason
Thanks for that, particulary interested in the front brake disc options. :thumbleft:
So Kjell, how sure are you that these parts will actually fit RD03's? I'm wondering because I've check the rear disc brake for example on www.cmsnl.com and it says that that brake was only used on CB 900's, not XRV's...
So where does this information come from? I'm not questioning your knowledge, I'm just wondering before I go out and spend $250 on parts that don't find.
Thanks.
Information came from a Swedish company selling aftermarket spare parts for Honda, Yamaha, Suzuki, and Kawasaki.
If You have other information stating that my write up is wrong, pls let me know, so I can correct the information.
If in any doubt, or if You received contradictory information then You would do vicely to check with someone that can guarantee
the parts are interchangeable.
As You already found out www.cmsnl.com is a sourcefull website/company
//Kjell
WOW, thats amazing, well done Kjell, and everyone here for their knowledge and support for one another, its a truly inspirational and vital resource. :thumbup:
zbell RD03
Hello,
When I need parts for my RD03 here in Australia, I look at the parts blow outs (microfish that the dealers have) to get the part number, then I call the local Honda shop to see if it is bike specific. If they can get it in, I order it otherwise I use this company base in the Neitherlands (csunl I think it is) to order the genuine Honda part - they are the expensive but the real part comes in the mail about 2 weeks later. I also have a '97 TransAlp that I do the same for. Honda sold the Transalp here in 1988 and the Dominator for a coulple of years but that is all, so someone helped me on this forum to locate parts.
I hope this helps.
I'm still after a pair of @750 Headlights (£130 new), does anyone know if there are any matching ones used across in the Honda range ever?
If so, it will broaden my search of bikes at bike breakers.
Grazie
thanks for advice..i just bought cagiva 750 elefant.brakes similar to 900 only 1 disc & brake calliper fitted..same size as 900..tried cb500 disc & dominator calliper & both fit.saved a lot of searching...good info to keep this..steve
NX650 RD02 Dominator Front brake master cylinder is the same as the XRV650, spent ages looking for a RD03 brake master cylinder with the straight connection instead of a banjo.
1 - 16 of 16 Posts
