1 - 20 of 154 Posts
Kymmy accepts no responsibility for this blondes c
I have touched on this in a few other threads but as they are more honda related thought it may be better to stick a thread here that not going to move others off topic.
ok a long time ago i joined this site to research the possibilities of building a Dakar rep bike, the first choice was the NXR, next up was a YZE then the goood ole elephant... well the NXR is just way too much of a one off build, the cost of a good donor bike to expensive and parts ridiculously dear so that was that. The elephant is a favourite of mine and is a stonking bike but lets be honest its also a white elephant as no body has really heard of it (for give all the puns!).. so Yamaha won.
after a lot of hunting around we found a somewhat neglected donor bike up in Wales for £300 which although needing a lot of work would suit the plan well.
So back in workshop she has been now been stripped and we have started to 'up grade' as much of the bike as possible in the direction of competent rally raid entry...
There has much been written about the pro's and cons of fork swaps, its sometimes complex and its always an issue with insurance companies, but as we will end having to insure as a modified i don't look at this as a problem merely just another 'item' to list on the bike spec paperwork. After a bit of research it turns out those nice people at Yamaha have stuck with the sane headstock dimensions for a long time and that means we can use the yokes and forks from a WR450 with minor changes. these monster USD units are built like a brick shit house and offer a massive 300mm travel. Like an idiot i have decided that the XTZ twin disk front wheel must stay as like on an AT it is really iconic of the bikes design. WR front disk has both a different offset and diameter so that means loads of extra work making up new calliper mount in ally, cutting off the old one and then welding the mew mount on using a jig... which we also need to make!!!
Other work in progress is the moulds for the rear tanks or hecktanks as they are normally known, these are a modification of the exsisting bikes panels that extend back behind the shortened seat to a filler, plan is to have these made in a resin/kevlar composite. estimations are that each side will hold around 5 lts of fuel and water.
One nightmare is to sort the dash, its amazing what has to be fitted in on the bike to do a rally raid.. roadbook, GPSr, UHF radio, safety beacon, and then either a stock dash or as we have opted a IMO digital dash. After a lot of mucking around its obvious that all that wont fit in a stock faring so another current project is to increase the space in the top of the faring... I should also say that i'm not keen to fix anything to the handlebars as its prone to damage....
more to follow!
Cant stop 'tinkering'
Sounds great - looking forward to some pics :D
i'm not sure if people are aware of the amount of time it can take to build a dakar bike - even a replica - up to a year in some cases - and thats by pros working full time :eek: (but this includes testing and development).
I can appreciate what you say about the dash and all the extra equipment you need to install - i had enough headaches fitting back all the standard stuff let alone extra rally computers.
Good luck.
Ant.
Discussion Starter #5 (Edited)
quite a few guys on the UK XTZ forum have gone the WR front wheel and single disc route and report that the breaking is weak due to the extra weight, others have then done the sport bikes big disc mod and they say that that is to harsh off road but great on tarmac... but that surely is a contradiction if you go to all the work of swapping out the forks in the first place... if I wanted a tarmac monster then I would buy a ducati lol !!!
lmao I have not given toooo many details of the build as I didn’t want to give it away but what the hell,
yep final engine will be the TRX850 with the 27' crank, yet again Yamaha have made a bike that excepts all the goodies from other models with a simple swap.. This engine is the dogs dangles!
Other mods are:
rear linkage, going to rework the link to allow ride height to be raised 2-3".
rear end, full WR mx style back end. small tail pouch for spares, LED light pod.
rear mount for both UHF radio aerial and GPSr power amp ariel.
rear wheel, rebuilt with stainless spoke, both hub and rim shot piened and black powder coated, new rear tyre (Michelin 'desert' with bib mouse).
rear renthal sprocket -1 tooth (45), stock 16 renthal front and new 520 DID gold ert 'X' ring chain.
front wheel, XTZ with twin 245mm discs, stainless spokes, both hub and rim shot piened and black powder coated, new front tyre (Michelin 'desert' with bib mouse).
front dual calipers with ebc kevlar compound pads, single rear calliper using ebc kevlar pads.(all disc's zinc plated)
dual stainless front brake hoses, single rear stainless hose, all fitting stainless not plated.
Large capacity resin/kevlar front fairing, larger dash area and increased air dam to accommodate larger rad & oil cooler (uses stock mounting points)
4 row alloy rad with additional 18% volume (custom fabricated by Pace products)
2 row alloy oil cooler (custom fabricated by Pace products)
Raidxtreme ally dash sub frame, mounting dash/fairing/lights and first aid kit.
Renthal dual wall handlebars with risers, brace, medium compound grips and pad.
Touratech Sport100r IMO dash and logger. Remote operation kit.
Touratech RB-TTi electric roadbook c/w led illumination and remote operation kit.
Yaesu VX1 UFH radio with remote mount antenna.
Garmin eMap GPSr with remote power antenna.
Raidxtreme VX tracker and distress beacon.
Polisport hand guards
Polisport WR front fender (high fitting).
Polisport YZ rear fender.
SR Racing fork brace.
Raidxtreme seat, dual layer foam with a suede/vinyl cover.
exhaust, stainless steel Laser enduro pro with ceramic uht black coating.
frame, shot piened and strengthened on engine mounts and sub frame connections. zinc primed and 2 pack pained.
ally bash guard with integral water tank, may end up in resin/kevlar and ally skin.
tank, errr... plan is to build a new one that will accept a hi-level K&N air filter in resin/kevlar, with increased capacity as the air filter box is not required. Estimated fuel capacity is around 30lts. Two new hecktanks in resin/kevlar rear mounted will provide an additional max 10 lts of fuel.
paintwork, main bodywork in Porsche sea blue, frame Porsche tundra met grey, engine as original. Forks and swing arm in silver zinc plate. new ally heat shields’, chain guards and infil as required.
graphics, high definition vinyl print to include all sponsors logos.
so there you have it a few hours in the workshop and she'l be sorted :confused:
Discussion Starter #6 (Edited)
oh.. and forgot.
Raidxtreme sealed loom (c/w paddock battery connector, self trip fuses, and soild state relays)
Xenon HID twin lights.
YB14L-A2 gel battery (190cca).
'tour de france' air horns.
variable length side stand, option on centre stand.
clear screen.
omg it goes on.. and on... and on!!!
hopefully the bike should be finished by the end of the year (with exception of the trx lump) as most the bits are just straight swaps....
A man without Ale.
:love6:Jenna (if only you an kymmy were not married:sad7:)
Sounds great. I will be watching this very closely, as i want to make my xtz (back in oz), in to a competitive rally bike when i get back.. so please please keep the details coming..
The mods sound great.. as you know I am particularity interested in the hecktanks (rear tanks.. literal translation from vaderspeak:rolleyes:), so if you would be sooo soo kind as to keep a detail diary of how that goes. I'll give you my first born child.. .. I am also VERY interested in the " variable length side stand".. I was just talking to MRS.X about making one but have not come up with a design that i feel would hold the bike with the vastly different loads that we can put on, it.. (the WP rear has been a god send, except for the angle that the bike can lean on some times... and then i have the heave back to up-right..:naka:)
In other questions are you coming to the national... it would be great to meet you both? I talk about you two all the time and it would be great to know who I am talkng about.
and who is going to ride this mean machine :evil5:
well short arse Kymmy cant even get her feet on the floor before i raised up the suspension so that rules her out.. oh well for the time being looks like it will have to be me...hu hum. :p
Xander had a few clear days to take a look at the bike and do a few measurements, also started the bodykit.
front fairing has been re worked so the screen is now at 80 degrees as apposed to the 45 degree its normally at ,plus i have moved the base of the screen forward by 4" so now the dash area is twice the size, i also managed to convert the fairing so that the top will take the clear screen as apposed to being solid and fixed. This means that you can fit a high screen or a low one depending on what use you have, it also means that the fairing can be made in two halves so its easier (and cheaper) to make with an additional bonus that the panel will be way easier to store and transport.
The lower half of the firing is going to get the jenna treatment, from the mock up it looks like i can gain 2" each side with a larger air duct this means that if the rad is off set to one side i then have space to fit a 4"oil cooler too! I have also made the air duct wider and lower this means that there is now room to fit the air horns under the fairing as well (compressor fits next to the catch tank under the seat).
Mocked up one of the hecktanks also, looks like it will a nightmare to mould though!... so far all the panels fit on the existing mounting holes.. only exception is lower fairing clip but this will be replaced as this new section will locate on the new bash guard anyway.
After 2 years i might be able to get to the lathe this week as we have moved all the cars and spares out of the workshop and into a new rented barn and i will then make up the side stand mod. the idea is a copy of a suspension leg adjuster on a Subaru rally car so it should be strong enough!!
It is made up of a stepped collar that fits in the side stand tube, it has a centre thread (m14x1.25) which accept another collar that will fit in the other half of the tube. This collar has a threaded section that allows you to lengthen or shorten the section, spacers are then fitted over the thread to the correct length and then the whole thing tightened up.. hay presto a variable length side stand....
hopefully will post a few pic's of the bits and pieces today, just about to collect a spare tank this morning that is going to be 'modified', so it wont be till later.
No idea about the national as we just cant work that far ahead as the work we do is very much week to week at best (like we had planed to be HU but ended up 2 days before organising a meeting at Goodwood with Bowler and Desertrose...) plus i am in hospital next month a few days and I am adamant that we get out to morocco asap ready for next year..... :cool: :cool:
A man without Ale.
That was the basic idea i was thinking about.. my only concern was the vibration factor and if it may vibrate lose and fall off, so i started to think some kind of lock system (beyond nylocks):D Then I started to think how great it would be not to need spacers so that i could adjust on the fly with out extra parts... then it got complicated.. and well that is just bad. (must use K>I>S>S>!!!).. so i put it into "to be though about later box".. I reckon you could sell that if you made em by they..
side question... what are you using to do the working sub-molds.. I have i the past used a fine metal mesh that bent and stays where you put it.. but cant find anything like that here.. :D
Xander,
I had a problem of my bike leaning over too much after raising the suspension - i took off the stand and cut about 4 " off the bottom of the leg, then welded in a large steel threaded bolt inside the leg, with a new steel tube covering the joint, then welded back on the bottom bit i cut off - if that makes sense - basically i extended the leg by about 2" to get it back to the correct lean angle when parked.
I know its not adjustable, but it was the easiest fix for me.
Ant.
A man without Ale.
Any news on that bike going it to production.. it may be the answer we have all be waiting for!
Discussion Starter #14
ok...
first question why do you need to adjust the stand on the fly... have you ever needed to adjust a stock stand (with stock ride height) on the fly? Adjusting the stand were making is by simply adding or removing the spacers, these will be ally so the weight increase should be minimal, when you have the length you want its either locktite or a small grub screw to lock it solid. As you say Xander KISS is a must.
for making up the mock ups we use polystyrene foam ( cheap from any builders merchants) in a slab form, it can be roughly shaped with a knife and then 'sanded', over the top this put a layer of packing tape and then 'soft body filler'... sand the whole lot back to the shape and surface you want... I apply a coat of HD coach paint between filler layers (normally 3 minimum ) as this prevents the soft filler becoming porous and screwing up the mould. We built a proto type Dakar escort (full on WRC 4X4 monster) for ford back in '98 using mesh as the base, its good for small a curvy areas but a nightmare for larger and flat surfaces...
sadly BYrd (belgarda racing) is producing sod all for the XTZ750 all the bits they are making (and have for several years now) are for the thumper.. if you want cheap BYrd raid bits then have a hunt around the boys in Dubai as that is the last round of the fia championship and thats were the bikes get stripped post season!!!
was going to post up the pics of the bodywork (top fairing, front n/s air duct and both rear hecktanks now 75% done) but like a moron left me phone with the pics on in the truck...DoHHHHHH :D
However on the flip side more goodies have arrived... Touratech IMO sport, Polisport mudguards, spare fuel tank (to be modified) and the tap i was waiting for to finish the top yoke....:p
Current jobs on the go: new LED rear light cluster, rear rack, and loom....
A man without Ale.
I like the idea of the grub screw.. now were to find the bits and bobs,,,,
As for adjusting it on the fly.. really I dont.. but I am a geek tweaker that is the son of a industrial chemical engineer .who taught me mostly everything I know about engines and tools. thus I always think of the most complicated fancy fangled way of doing something.. then I wake up and so it simple! :) ..
The (unjustifiable) justification for on the fly adjustment.. is simply it would be cool to be able to park on an angled bit of ground and adjust the stand as needed... (but even that would be far more hassle then it would be worth)... just imagine balancing the bike fully loaded as you are lengthening the arm, and you make it too long or to short and squish... ) See i come up with these things and then abandon them... hey I even mocked up a push button hydrolic center stand. out of a bunch of parts we were throwing out in the lab. yes it worked and it could have been fitted easily enough.. but why was the most important question.. the answer i got to look like i was working but really just playing... :)
Site Admin
sadly BYrd (belgarda racing) is producing sod all for the XTZ750 all the bits they are making (and have for several years now) are for the thumper.. if you want cheap BYrd raid bits then have a hunt around the boys in Dubai as that is the last round of the fia championship and thats were the bikes get stripped post season!!!....
Jenna - when you say 'thumper' are you talking about the XT600 / XT660 and where can I find the parts they are still making? - is there a weblink available? And I know it's asking a lot, but do you also have any contact details/links for the 'boys in Dubai'
Discussion Starter #18
na sorry stormforce all the current bits are for the xtz660 which is a different frame to the xt. they were behind the 2004 dakar proto (think it was no'81) which was hinted as bing a test bike but 3 years on and nothing has appeared. on the flip side its byrd that are making the new ttr600 race bikes on the quiet for Yamaha France!
If your looking at buying bits out of Dubai then ask on adv first coz most the guys in Dubai are frequent forum posters otherwise have a look in the sponsors list for the uae desert challenge.
Xander your a tinkerer.... repeat after me ..."if its not bust dont FIX it!!"
Discussion Starter #19
few quick pics after end of week one....
week two:
jobs are strip bike down to bare frame, strip & check engine (new gaskets), shot blast & paint frame, refit engine and refit front end.... oh and put the pile off bits taken off on ebay.
money spent so far = £640 (not including take off's to be sold) :thumb:
Site Admin
Jenna - is this what your basing your build on? - AWESOME BIKE:love4:
1 - 20 of 154 Posts
