Returning from SW today and about a 100km from house in Belgium I get fuel and when I go to start bike nothing. Hit starter again and it fires but dies, goes on a few more times so I pulled in to a stall. Pulled hose off of filter and lots of fuel flow. I go to pump side towards carb and nothing even when it fired for a split second no fuel coming out at all. When had just pulled same hose day before to get someone fuel and their was no issue. Had been riding all day returning from Switzerland and it ran great. I then remembered someone had said run fuel direct so I undid the line from carbs to pump and hooked direct to fuel filter and it started running. Manage to limp to house at 40-100kph in between it running out of fuel here and there I assume because direct line could not supply enough. When I had gotten off of freeway I heard a buzzing and it was the fuel pump running again, it had not been running previously and it was hot. So am I correct in assuming it is probably a fuel pump issue? it looks to be an original pump. And yes I have heard replace with a facet pump which I will do at this point. Also with the original having been running for awhile is it still rebuild-able as a spare? or just dump it. Figure it would not hurt to have an extra for trips at this point. Thanks
