Successfully installed a new universal kit on the @ yesterday, but have a question about the flow rate. I have the adjustment dial up to 9-MAX and it is only dropping out at about 1-2 drops per minite, timed both at the garage and at home this morning, is this usual? Is it because it's a new unit that the rate is so slow? I noticed in other threads that the usual setting is around 5-6 on the dial.
(I have checked the discharge line and it isn't kinked or squashed, etc. The reservoir is under the left side cover, just down from the rectifier and the breather line tubing neatly shielded and tucked behind the CDI unit. The vacuum line is attached as per Scottoiler instruction and the RMV seems to be working properly. The average daily temperature here is about 32-36 deg. C, so I don't think it's a fluid viscosity problem as the oil is the high temp variety, 20-40 deg.C type)
Anyone got any ideas please? :scratch:
