1 - 16 of 16 Posts
Cleaned my brakes properly last night but due to low light conditions I did not notice that the rear brake hose had come out of it's clip and was touching the exhaust. This is the result..
Could've been much worse I guess because I had brake fluid all over the right-hand side of the rear tyre. Still feel like an idiot though!
Anybody know what the cheapest replacement would be and where I can get it? I've not real desire to fork out a lot of money on a braided hose for the rear brake.
A man without Ale.
Both wemoto and david silvers do lines..
http://shop.wemoto.com/index.dyn?oid=5834417
http://www.davidsilverspares.co.uk/parts/pattern-parts/
and
EEP!
A lot of bike shops can make up a braided hose for you if you turn up with the original line for reference. Cheaper than buying kits. Bill Bunn out in Ealing did one for my old Toxic ******* for good money.
Would probably be cheaper than buying an original expandahose line too.
Spoke to my local bike shop and they're asking £25 for a replacement braided hose. They'll make it up and install it on the spot for £25.
David Silver wanted £49 for the Honda one and £37 for a braided hose.
Wemoto wanted £29 regardless of whether it's braided or not.
Wing Commander
Replaced mine with braided so have one here if you need it. Could bring it over tomorrow.
Need Constant Supervision
Yes you idjit should of known when I accidently popped the piston out of the front caliper last night that something was bound to happen on your way home like normal :D
We have been through this procedure several times now over the years. You bring your bike to my place, we fix it till it's broke and then you go 1/2 a mile down the road before you return to tighten up or fix something else again. Only then do you go home with it semi sorted :rolleyes: You missed a step last night so that's what happens :toothy2: If you can stick braided hoses on the bike would be much better already. Could always take up Whealies offer and save up for a full set. Just put a weekend aside for it so we don't run out of time :thumbleft:
Wing Commander
Can bring it over to you in the evening or up to town (if you are still in Westminster) during the day.
Tropical Member
Went the whole hog last year and replaced all hoses with the Wemoto "german stuff", brought me alot more peace of mind in the long run.:thumbup:
ignore the vain
I usually scour ebay for used braided hoses had some real bargains and made a fair few ets up saves buying those kits. On avaerage pay a quid for em:toothy1:
Discussion Starter #10
Whealie to the rescue!! Thanks dude! Man I love this site
Thanks Whealie, got the goods Lootch hopefully we won't break something else whilst fitting it :joker:
Discussion Starter #12
No, I got home without any problems - still a new sensation for me :D.
Thanks again Whealie!
Wing Commander
No probs. It was sat in my garage for three months unused. Glad to be of help.
Wing Commander
Mav, you mentioned some brake bleeding kit you used. Don't forget to post the details.
Discussion Starter #15
I've got Speed bleeders on my front calipers which work really great. Much less effort than bleeding them the usual way or using a vacuum pump. The rear is standard but that took the best part of 5 minutes to change the fluids.
Wing Commander
1 - 16 of 16 Posts
