raising transalp suspension
5.9K views 8 replies 6 participants last post by  piguglyshandydrinker
#1 ·
Has anybody found a reasonably easy way of raising the suspension for an xl600vr?
#5 ·
Feel free to bring it over if you want to do any work here. Well equipped garage and lots of tea.. I'm pretty much trapped here during the day anyway.
#9 ·
I did it on a 1200 Bandit (don't ask....)
I just removed the 'dogbone' links, cut the required ammount with the grinder & welded back together - worked a treat. No reason it couldn't work on anything else.
(Although they may need lengthening instead, guess it depends how the linkage is set up.)
It must be a good weld as they are under a lot of stress
Phil
