Removing the shock without a centre stand?
5.3K views 14 replies 10 participants last post by  Mack1
#1 ·
Hi has anyone changed their shock without the benefit of a centre stand? If so any advice much appreciated (apart from "buy a centre stand") :thumbup:
#2 ·
Hiya deiferdog; I haven't but can't see why, so long as you can use something to stand in as a centre stand, you can't do it without actually having one. A bit of leverage and some bricks and 4x4 or something seems likely to give you what you need to do the job :)
#3 · (Edited)
I did my complete restoration with the centre stand removed & haven't bothered replacing it since.
Never had any problem with bike falling off stands, but it collapsed an hour into the resto when the damn centre stand retracted as I removed the front wheel !!
What made it worse was I'd removed the sump plug & was draining the oil as the bike collapsed & smashed the bowl I was collecting the oil in !!
There's alot of oil in an @ I can tell you, especially as it spreads across the shed floor :mad:
You'll need the following...
2 axle stands or something suitable
2 foot length of 3x2 or larger
Trolley jack
Remove sump guard
Stick the timber on top of the jack 'cup' then place this squarely under the frame rails below the swingarm pivot
With a friend or two steadying the bike, slowly jack the bike up until it's rear wheel clears the ground.
Place an axle stand under each end of the 3x2 & gently lower until the bike rests on the frame rails & front wheel.
Give it a gentle shake to make sure all's good then get the plus-gas out cause your gonna need it ;)
Ps... Here's a link to my rebuild showing the bike sitting on axle stands with a piece of carpet to protect my bling frame
http://www.xrv.org.uk/forums/africa-twin/85198-not-another-rebuild.html
#6 ·
By the way...
Just a little friendly advice, incase you didn't know... :cool:
When you come to replacing the shock in the frame, you have to attach the bottom linkages to the lower shock eye, then attach the top mount before attaching the bottom links to the frame & swingarm
I made the mistake of attaching the shock to frame, the linkages to the frame & swingarm & then found you cant get to the bottom shock mount because of the way the linkage sits :(
#13 ·
Checked the ABBASTANDS site but they don't list one. Have emailed them to ask if they would do one but not holding my breath on that one......
I have contacted ABBA STANDS in the past and they don't make a stand that will take the Arica Twin.
Try using a strap through the rear wheel and round the seat to hold it in the correct position. I did a shock replacement a short time ago it's listed on here under (Time to fit the Nitron) if your interested, i had no problem fitting the top of the shock to the frame first.
good luck:thumbup:
nigel.
#10 ·
I use a motox stand to do the work on the vigor , but the @ maybe to heavy for that , I can just about get the Vigor on it by myself,
the little TDR250 stroker is a cinch to put on it though
#12 ·
#14 ·
I've used various methods over the years. The last was the best.
