720cc KIT for NX or FMX
32K views 11 replies 7 participants last post by  berchardelacour
#1 · (Edited)
As all we speak about modifications on our engines, I came across this, which is a 720cc bore kit
XR650L Big Bore Kit
Honda Big Bore Kits for Dirt Bikes, ATVs, and Street Motorcycles
KIT HAS A JE PISTON AS STATED HERE.
L.A. Sleeve-Honda
XR650L 1993-09 720cc Big Bore Sleeve Kit $615.00 JE 9:1 Piston
NEWS
I asked this seller on ebay
XR650L BIG BORE 720cc KIT: eBay Motors (item 130384823526 end time Sep-17-10 12:44:37 PDT)
He says it got two kind of pistons 105mm and 106mm at 10.1 compression. Kit come with sleeve ecc.
REMEMBER:
Kit requires a case mod, possibly as I did for my 104mm piston and sleeve from egu-motoren.de
Uploaded with ImageShack.us
The CASE MOD/BORE is required to fit in the new sleeve.
I am in contact with egu-motoren to see if my egu-motoren sleeve of 104mm can be bored to 106mm. If so I won't need new sleeve in case I decide to upgrade
NEWS 02/09/2010
The reply of the Egu-Motoren.de was
we can offer you following racing-parts:
Cylinder 108mm
250,00 EUR
Piston 108mm
295,00 EUR
Cylinder Head Gasket 108mm
59,00 EUR
#7 ·
And the starters on these bikes aren't exactly keen in the first place :D
Grind, squeak, grind, squeak BROOMBA...
#6 ·
Quite right. I had an XBR500 running a high comp Wiseco big bore kit. It was interesting kick starting when the starter fried itself - but at least that was an option. There is no way it would bump start though so a 720cc high comp Dommie had better have a good starter motor unless it's an early kickstart model.
#11 ·
I use hi compression pistons since 2006 with no problems.
The NX650 and xr650l (actually same engine) rod is quite durable and has no need to be upgraded.
Since 2008 I admit that I use an oil cooler from egu-motoren.
Anyways I ll give also my experience.
I have used the bike as stock for almost 4 years. The first year os usage was the very first and ONLY year that I did found myself at service (oil change) with just 1lt of oil in the engine instead of almost 2. It was all burned since with no modifications I did pushed a lot the bike to its limits and hi rpm in Greek summer time. YEt there was no issue in the engine
Since I upgraded the engine I had no needs to overpast 5500 rpm as so many times as stock. All the power was handy. I can assure you that I do 7000-10.000km every year, all of them in spring, autumm ans specially summer in Greece, where temperature rises well above 34C. Never had problems with oil. I also use oil deepstick and check everything.
Now i change oil every 4000km instead of manual's 3200
I can understand your worries but this engine is TOO reliable.
Last time with 11:1 compression I have forgotten to fill in plus 500ml oil for the oil cooler. Yet the bike was some 8C hoter but I never exceeded 90C in full summer time...
The only problem with 11:1 is to have a mechanic who really knows to setup the carb so there is no pinging. Otherwise 10:5 compression is impossible to ping even with a less precise tuneup of the carb.
If I ll ever install a bigger piston (108mm) I will avoid 11:1 and go for 10:5 or 10:1.
Good evening
