I have touched on this in a few other threads but as they are more honda related thought it may be better to stick a thread here that not going to move others off topic.
ok a long time ago i joined this site to research the possibilities of building a Dakar rep bike, the first choice was the NXR, next up was a YZE then the goood ole elephant... well the NXR is just way too much of a one off build, the cost of a good donor bike to expensive and parts ridiculously dear so that was that. The elephant is a favourite of mine and is a stonking bike but lets be honest its also a white elephant as no body has really heard of it (for give all the puns!).. so Yamaha won.
after a lot of hunting around we found a somewhat neglected donor bike up in Wales for ÂŁ300 which although needing a lot of work would suit the plan well.
So back in workshop she has been now been stripped and we have started to 'up grade' as much of the bike as possible in the direction of competent rally raid entry...
There has much been written about the pro's and cons of fork swaps, its sometimes complex and its always an issue with insurance companies, but as we will end having to insure as a modified i don't look at this as a problem merely just another 'item' to list on the bike spec paperwork. After a bit of research it turns out those nice people at Yamaha have stuck with the sane headstock dimensions for a long time and that means we can use the yokes and forks from a WR450 with minor changes. these monster USD units are built like a brick shit house and offer a massive 300mm travel. Like an idiot i have decided that the XTZ twin disk front wheel must stay as like on an AT it is really iconic of the bikes design. WR front disk has both a different offset and diameter so that means loads of extra work making up new calliper mount in ally, cutting off the old one and then welding the mew mount on using a jig... which we also need to make!!!
Other work in progress is the moulds for the rear tanks or hecktanks as they are normally known, these are a modification of the exsisting bikes panels that extend back behind the shortened seat to a filler, plan is to have these made in a resin/kevlar composite. estimations are that each side will hold around 5 lts of fuel and water.
One nightmare is to sort the dash, its amazing what has to be fitted in on the bike to do a rally raid.. roadbook, GPSr, UHF radio, safety beacon, and then either a stock dash or as we have opted a IMO digital dash. After a lot of mucking around its obvious that all that wont fit in a stock faring so another current project is to increase the space in the top of the faring... I should also say that i'm not keen to fix anything to the handlebars as its prone to damage....
more to follow!
more to follow!
