7K views 10 replies 6 participants last post by  Loggy
#1 ·
Hi all,
Anyone know of anywhere that makes a replacement rear hub for the AT or any other brands/models that share the same axle diameter and similar spacing?
Any help appreciated.
Slidey
#8 ·
The bearing housings are looking a bit tired...
I want to build a strong rear wheel for racing and need to start with a good base.
Slidey.
#9 ·
I know that Bruno (Porompompero) used a KTM rear hub to build his Excel 18" x 2.5" (36 spoke hole as well which is readily available) rear wheels for his project bikes. Much better choice of tyres for the mud biased racer :thumbright:
You will have to fit a Brembo rear brake and to fabricate the right spacers but with the advantage of 4kg weight loss and if you wish you can also use a 520 chain set.......
